Inspire is a concept design tool which you can use to run structural optimizaiton, finite element analysis, motion analysis,
and additive manufacturing analysis.
Configure a model by activating or deactivating parts so they are included or excluded from calculations like mass summaries,
static weight calculations, optimization, etc.
Browse and organize all of the entities in your model.
Find Find entities in the model that contain the search string you enter. The search results are not filtered.
Search and Filter
Search entities and automatically filter the results to only display the entities that contain the search string. You can also filter by entity type.
Show or Hide
Show or hide an entity by clicking its icon in the Model Browser or using the context menu.
Mass Calculation
Mass calculation allows masses to be calculated and displayed in the Model Browser.
Configure a Model
Configure a model by activating or deactivating parts so they are included or excluded from calculations like mass summaries, static weight calculations, optimization, etc.
Manage Load Cases
Create load cases to define sets of loads, supports, and other entites that act on a model.
Customize the Model Browser
Display properties such as mass, element size, and thickness in columns in the Model Browser.
