Start using Inspire with our interactive tutorials.
Learn how to create and modify PolyNURBS.
Discover new features and enhancements.
New to Inspire? Learn the basics here.
Get started learning how to adjust the view, move parts, run an optimization, and export files.
Learn how to create 2D sketches and parametric parts, prepare and simplify solid geometry, and model surfaces.
Learn how to create a PolyNURBS part using primitives and by adding and removing blocks.
Learn how to edit PolyNURBS objects and the various selection techniques that are available.
Create the basic shape of a computer mouse using PolyNURBS modeling techniques.
Define contacts, create fasteners, and connect parts with spot welds.
Run a baseline analysis and analyze a generated shape.
Learn how to run different types of optimizations and compare results.
Define joints and motion contacts, create motors and actuators, run a motion analysis and plot the results.
Learn how to prepare, analyze, and export parts for 3D printing.
Create parametric sketches, geometry, and PolyNURBS with construction history and variables.
Set up your model and run a structural analysis or optimization.
Set up and run a motion analysis, plot the results, and export the results.
Set up and run an additive manufacturing, porosity, or thinning analysis.
Learn how to access the Inspire Python API including online help, quick start demos, and the Extension Manager.
View the glossary, frequently asked questions, and errors and alerts.
Learn keyboard shortcuts and mouse controls for common operations.
