OS-E: 7000 Response Spectrum Analysis
Demonstrates the response of water filled elevated tank structure.
Figure 1. FE Model
Model Files
The model file used in this example includes:
wtank_srss_cqc.fem
Model Description
- FE Model
- Element Types
- CTRIA3
- Linear Material 1: STEEL
- Young's Modulus (E)
- 2.1e5 MPa
- Damping coefficient
- 0.02
- Density (Rho)
- 7.9e-9 t/mm3
- Linear Material 2: STEEL_SANDWICH
- 3e4 MPa
- 0.02
- Density (Rho)
- 9e-10 t/mm3
Results
Figure 2. Maximum Displacement of the Structure
Figure 3. Maximum von Mises Stress in the Structure
