Perform Final Post-Optimization Analysis
Import the Model
Set Up the Model
Import Final Optimization Properties
- In the Import Browser, File field, browser for the oht_opti_ph3.prop file.
- Under Import options, select FE overwrite.
- Click Import.
Edit the Contol Cards
Delete the Optimization Entities
- In the Model Browser, right-click on the Design Variables folder and select Delete from the context menu.
- Click Yes to continue.
- In the Model Browser, right-click on the Optimization Responses folder and select Delete from the context menu.
Review the Model
Figure 1. Model Thickness with Half of the Model's Elements Masked
Submit the Job
View the Results
Figure 3. Maximum Normal Y Strain Across all Plies. No element exceed 0.007 me.
to open the
