Plotting and Viewing the Report – AutoTire
For each tire event, a report is generated. These reports are automatically created using templates. You can also create your own templates for reports or plot the signals/outputs in HyperGraph.
Like any other report in MotionView, these can also be accessed from: , after the event is exported and executed in MotionSolve.
Figure 1. Plotting Reports
Lateral Slip Test
- Animation
- Raw signals from the event
- Cross plots of: Lateral Force and Aligning Moments vs Slip angles for various vertical loads and camber angles as specified in the event.
Figure 2. Lateral Slip Test - Cross Plots
Longitudinal Slip Test
- Animation
- Cross plots of: Longitudinal Force and Longitudinal Slip for various vertical loads as specified in the event.
Figure 3. Longitudinal Slip Test - Cross Plots
Vertical Load Test
- Animation
- Cross plots of: Tire Contact Patch Force [Z] vs Wheel Center displacement.
Figure 4. Vertical Load Test - Cross Plots
