A multibody system study generally involves the following broad steps. The following sections give a brief introduction
on using MotionView and the related HyperWorks products to conduct such a study:
MotionView supports and encourages a modular model building approach. Different entities can be aggregated into containers, thereby
arranging a model into a collection of different assemblies or sub-systems.
The expression builder allows you to enter expressions in text boxes without extensive typing and memorization. It
can be used to construct mathematical expressions that are a function of the model parameters.
MotionView contains an implicit variable called SolverMode. In MDL, SolverMode can be used in an "if" context to define topology (include Templex templates). MotionView retains the "if" result for both cases so that when you toggle the solver type, the associated text becomes active
within the user interface.
Batch mode allows you to generate a solver input model file from an MDL model file and run the solver job without starting
the MotionView user interface.
MotionView allows you to create and select certain types of
entities in a collector by picking an edge or surface of certain Graphic entities. To enable
this feature, activate the Allow CAD feature recognition for picking option in the Build
Model section of the Options dialog.
Currently, the following reference entities can be added on-the-fly and selected while
defining other entities, using the appropriate collectors available on its panel:
Point
Vector
The Graphic entities that allow such operations are: Cylinder, Box, and CADGraphics.
