HWCFD-T: 1010 Wrapping Workflow
Before you begin, click here to download the tutorial models. Extract PowerTrain_Model_Defeaturing.hm from the zip file.
If you have local help installed, you can access the model files in <Altair Installation>\tutorials\hwdesktop\hwcfd.
Group the Solids to be Wrapped
Convert CAD Geometry to an FE (Tessellated) Model
Cap Holes and Other Openings
Small holes and other openings which only increase the mesh count and do not contribute to the simulation are capped/closed off before the wrapping of the geometry is done.
