Change Mesh Display Settings
Change the display of mesh in the modeling window by configuring the mesh display settings.
From the View Controls toolbar, click and select a mesh display option.
  1. Geometry Only. Display geometry only, no mesh
  2. Mesh Only. Display mesh only, no geometry.
    Note: You can still perform selection as if geometry is visible.
  3. Mesh Only Without Mesh Lines. Display mesh only without mesh lines visible.
  4. Geom and Mesh. Display both geometry and mesh.
