This section presents the hardware configurations required for Flux
2021.2 2D, Skew, 3D and PEEC.
Processor
The processors required to run
Flux 2D, Skew, 3D and PEEC
should have the following characteristics:
| Element |
Characteristics |
| Processor |
- Intel or AMD
- 64 bits
- multi-core
Minimum configuration (hard disk and RAM)
The minimum configuration required to run
Flux 2D, Skew, 3D
and PEEC are:
2D |
Skew/3D |
PEEC |
| Hard disk |
250 GiB |
500 GiB |
50 GiB |
| RAM |
8 GiB |
16 GiB |
16 GiB |
Recommended configuration (hard disk and RAM)
The recommended configuration required to run
Flux 2D, Skew,
3D and PEEC are:
2D |
Skew/3D |
PEEC |
| Hard disk |
500 GiB |
1 TiB |
100 GiB |
| RAM |
16 GiB |
64 GiB |
64 GiB |
Graphic card
The graphic cards required to run Flux 2D, Skew, 3D and PEEC
| Element |
Characteristics |
| Graphic card |
- OPENGL V2.0 compatible for an optimal graphic quality
(see below)
- NVIDIA chipset recommended
Flux uses the OPENGL V2.0 graphic technology. This technology
provides improved rendering and smoother motion when moving objects.
This technology requires:
- the use of a graphic card compatible with OPENGL V2.0
- the latest version of the graphic card driver supplied by the
manufacturer
A summary of the conditions of use is presented in the table below:
| Conditions of use |
Installation of a graphic card compatible with OPENGL
V2.0:
- NVIDIA GeForce 6200 and higher
- ATI Radeon X1300 and higher
| Installation of the latest version of the card driver
Warning: The use of graphic chipsets with shared memory is not
recommended.
It is preferable to use graphic chipsets with dedicated
memory.
