Periodic Boundary Conditions (PBC)
Periodic boundary conditions allow for analysing large, uniformly spaced, repetitive linear and planar structures, for example, frequency selective surfaces (FSS).
Basic antenna and EM concepts are given that provide a foundation for understanding the different solver methods in Feko.
Solver methods can be categorized as either source-based methods or field-based methods. Understanding the main differences between these two categories helps to understand and choose an appropriate solution method for each application.
The Solver includes multiple frequency and time domain solution methods. True hybridisation of some of these methods enables efficient analysis of a broad spectrum of electromagnetic problems. You can also use more than one solver method for cross-validation purposes.
Full wave solutions rigorously solve Maxwell's equations without making any assumptions regarding the nature of the electromagnetic problem. The solution can be either in the frequency or the time domain.
Asymptotic solution methods solve Maxwell's equations, but make certain assumptions regarding the nature of the problem. Feko provides various high frequency asymptotic solution methods that assume the frequency of interest is high enough that the structure is much larger than the wavelength.
A solution method is selected based on the electrical size of a problem, the geometrical complexity and available computational resources.
Model complex cable-bundle networks using full-wave simulations.
Infinite and finite periodic structures are efficiently modelled using special features available in Feko.
The domain Green's function method (DGFM) is a perturbation approach where the mutual coupling between array elements is taken into account when calculating the Green’s function for each element. The current distribution on the entire array geometry is obtained by solving each element independently, leading to a significant saving in both runtime and memory usage.
Complex feed networks can be simplified by including them as a circuit representation using general network blocks.
The windscreen antenna solution method reduces the computational requirements by meshing only metallic elements while analysing the behaviour of the integrated windscreen antennas within their operating environment. The analysis can take into account the physical features of windscreen antennas and their surroundings.
Geometric symmetry, electric symmetry and magnetic planes of symmetry in a model can be exploited to reduce runtime and memory requirements.
Provided are the formulations and concepts to define frequency-dependent dielectric media and anisotropic media (3D).
