Real Ground
A real ground can be modelled with the reflection coefficient approximation or the exact Sommerfeld formulation. Real grounds are used to model the effect of non-ideal grounds such as the earth (wet or dry ground).
Basic antenna and EM concepts are given that provide a foundation for understanding the different solver methods in Feko.
Solver methods can be categorized as either source-based methods or field-based methods. Understanding the main differences between these two categories helps to understand and choose an appropriate solution method for each application.
The Solver includes multiple frequency and time domain solution methods. True hybridisation of some of these methods enables efficient analysis of a broad spectrum of electromagnetic problems. You can also use more than one solver method for cross-validation purposes.
Full wave solutions rigorously solve Maxwell's equations without making any assumptions regarding the nature of the electromagnetic problem. The solution can be either in the frequency or the time domain.
The MoM is the default solver in Feko. A simple electrostatic example is used to convey the basics of the solver.
The usage of a dense matrix in the MoM implies a limit to the size of the problem that can be solved. The limit is determined by the available computational resources.
Specific methods, which can also be categorized as MoM methods, are tailor-made for solving dielectric bodies.
Numerous features and optimised electromagnetic (EM) analysis options for the method of moments (MoM) are available.
Multi-layered dielectric media can be modelled with Green’s functions. Example of structures that are efficiently modelled with the planar multi-layer substrate method include printed circuit boards (applications using microstrip and stripline structures).
The numerical Green's function can be used for problems containing static and dynamic parts, allowing re-use of the static part of the solution in subsequent simulations to improve overall performance.
Multiple layers of thin dielectric sheets and anisotropic sheets can be analysed using a single meshed surface. Typical applications are the analysis of radome covered antennas.
The effect of dielectric-coated wires can be modelled using an equivalent impedance or as an equivalent volume current.
The multilevel fast multipole method (MLFMM) is an alternative formulation of the technology behind the method of moments (MoM) and applies to much larger structures (in terms of the wavelength) than the MoM, making full-wave current-based solutions of electrically large structures a possibility.
The relevant integral equation method can be used to solve a model to either obtain faster iterative or higher numerical accuracy when using the MoM or MLFMM.
The adaptive cross-approximation (ACA) is a fast method similar to the multilevel fast multipole method (MLFMM) but is also applicable to low-frequency problems or when using a special Green’s function.
The finite element method (FEM) is a solution method that employs tetrahedra to mesh arbitrarily shaped volumes accurately where the dielectric properties may vary between neighbouring tetrahedra.
The finite difference time domain (FDTD) is a full wave time domain solution method, and Fourier transforms are applied to convert the native time domain results to the frequency domain.
Asymptotic solution methods solve Maxwell's equations, but make certain assumptions regarding the nature of the problem. Feko provides various high frequency asymptotic solution methods that assume the frequency of interest is high enough that the structure is much larger than the wavelength.
A solution method is selected based on the electrical size of a problem, the geometrical complexity and available computational resources.
Model complex cable-bundle networks using full-wave simulations.
Infinite and finite periodic structures are efficiently modelled using special features available in Feko.
Complex feed networks can be simplified by including them as a circuit representation using general network blocks.
The windscreen antenna solution method reduces the computational requirements by meshing only metallic elements while analysing the behaviour of the integrated windscreen antennas within their operating environment. The analysis can take into account the physical features of windscreen antennas and their surroundings.
Geometric symmetry, electric symmetry and magnetic planes of symmetry in a model can be exploited to reduce runtime and memory requirements.
Provided are the formulations and concepts to define frequency-dependent dielectric media and anisotropic media (3D).
