Define Pulse Mathematically
Define a time pulse using an analytical equation.
Figure 1. Define a time signal using an analytical equation.
- Time axis unit
- Specify the unit to be used for the time axis.
- Total signal duration ( )
- The total length of the signal in the specified units.
- f(t)
- Analytical equation describing the input pulse, where “t” can be used as the input time variable.
- Number of samples
- The number of samples taken from the signal’s analytical equation.
