Exporting an Image
Export an image of the active view to file.
On the Reporting tab, in the
Export Images group,
click the
Export image icon.
Figure 1. The Export image dialog. - Select a view to export.
From the Image format
drop-down list, select one of the following:
- PNG
- BMP
- CUR
- ICNS
- JPG
- PBM
- PGM
- TIF
- WBMP
- WEBP
- EPS
- EMF
From the Export size
- Same as source
- QQVGA (160x120)
- QVGA (320x240)
- VGA (640x480)
- SVGA (800x600)
- XGA (1024x768)
- SXGA (1280x1024)
- Custom
Click OK.
The Image export file name dialog is displayed.
- In the File name field, specify the file name of the exported file.
- In the Save as type, specify the file type of the exported file.
- Click Save to export the active view to file and close the dialogs.
