Duplicating a Cartesian Surface Graph
Make a copy of the current Cartesian surface graph complete with all the settings.
Use POSTFEKO to validate meshed geometry and analyse and post-process results.
View the main elements and terminology in the POSTFEKO graphical user interface (GUI).
POSTFEKO has various default settings that you can configure to customise it to your preference.
A number of rendering options are available to ensure that 3D models and graphs (containing a large number of sample points) are rendered efficiently.
You can add a model, open an existing project and save the project.
Import text files, native data files and Touchstone format files.
POSTFEKO supports the export of native file formats. These files can be exported to use in other sessions or when further post-processing is required.
The terms, dataset, slice, trace and 3D result, are used extensively in the documentation. Review the definitions to get a better concept of these definitions.
Display result data on a graph to allow visual interpretation of the data in a human-readable format, as well as to communicate the results in reports and presentations.
A Cartesian surface graph is a flat colour plot with results plotted against two independent axes.
Create a new Cartesian surface graph for displaying data.
Modify the graph title, graph footer, vertical axis label and horizontal axis label.
Enable the major and minor grid lines for surface graphs as well as the grid labels.
Change the line style, line colour and line weight of the title, footer or axes from a selected surface graph.
Lock the proportional relationship between the independent axes on Cartesian surface graphs to keep the graph dimensions undistorted and true to the 3D model.
The two independent axes on a Cartesian surface graph can be interchanged when required.
Specify the range for the major axes.
Change the order in which values are plotted along the axis of a Cartesian surface graph.
Stores a local copy of the underlying data that is represented by the Cartesian surface graph. By storing a local copy, you can modify the existing model and compare the old results to the new results.
Specify the number of samples for continuous results displayed on surface graphs.
Read a single point from a Cartesian surface graph result by adding a quick single point annotation.
Add a custom point annotation to a Cartesian surface graph to read the value of a point and highlight this point of interest on the graph.
Adjust the legend range for the current active surface graph.
A number of settings are available that affects how a result is scaled and displayed in a surface graph. These settings influences the colour scaling of the legend and displayed colour range.
Retrieve the plotted data and save to file.
View the simulation data in a 3D view to allow visual interpretation of the data in a human-readable format, as well as to communicate the results in reports and presentations. The 3D view can also be used to verify that the CADFEKO or EDITFEKO model is correct.
The Solver contains a number of frequency domain solution methods, as well as a time domain solution method. By default, all simulation results are obtained in the frequency domain, unless explicitly using the time analysis tool in POSTFEKO to convert the results to the time domain.
With the time analysis tool in POSTFEKO, electromagnetic scattering problems can be analysed in the time domain. The time domain results are obtained by applying an inverse fast Fourier transformation (IFFT) on the frequency domain simulation results.
Use animation to obtain a better understanding of results or export the animation to use in a presentation or report.
POSTFEKO is a useful tool to help analyse and present data in a useful format. It is often required to use the processed results in a report or presentation. To help make it easier to generate these reports, several tools are available in POSTFEKO.
Feko provides a powerful scripting language that allows you to create scripts that control CADFEKO and POSTFEKO.
POSTFEKO has a collection of tools that allow you to quickly validate the model, for example, measure distances, measure angles and finding specific mesh elements.
View the files associated and generated by POSTFEKO.
