Exporting Data
To export data, select the model, its configuration and the specific results to export to a native file format.
  1. On the Home tab, in the File group, click the   Export icon. From the drop-down list, select the file format to export.
  2. In the Source panel, select the required configuration.
  3. In the Results panel, select a result for the selected configuration.
  4. Under Result options, specify the result-specific parameters.
  5. Click OK to close the dialog.
  6. Specify a file name and click Save.
    Figure 1. An example of the export dialog when exporting near field data.
