Specifying the Grid Spacing
Specify the grid interval for the major (and minor) grid.
- On the Cartesian context tab, on the Display tab, on the Axes group, click the Axis settings icon.
Select the axis that you want to modify.
- To modify the grid range for the horizontal axis, click Horizontal.
- To modify the grid range for the vertical axis, click Vertical.
Modify the major grid spacing.
Under Grid spacing, select one of the following:
- To automatically determine the major grid spacing for the graph, select the Automatically determine the major grid spacing check box.
- To specify the major grid spacing, clear the Automatically
- In the Major grid spacing field, enter a value for the major grid spacing.
Modify the minor grid spacing.
- In the Minor grid subdivisions field, enter a value for the minor grid spacing.
- Click OK to apply the settings and to close the dialog.
Enable the minor grid to view the grid spacing.
- On the Cartesian context tab, on the Display tab, on the Minor grid group, click the Minor grid icon.
