Defining an Optimisation Mask
An optimisation mask is a set of values that form a continuous line (or trace). Use a mask for specifying a specific performance curve for a requested output.
The workflow for setting up an optimisation in CADFEKO is explained.
Use the most suitable option for launching OPTFEKO.
Use the most suitable option for launching OPTFEKO in Linux.
Use the command line arguments to pass additional information to OPTFEKOwhen it is launched.
The duration and accuracy of an optimisation depends on the selected optimisation method and stopping criteria.
Specify the variables to alter during the optimisation run.
A graphical approach to define an optimisation search. More complex scenarios is handled by a mask, where the goal shape is visually known, for example, the desired bandpass and bandstop regions of a filter.
Perform complex optimisations with masks by specifying a variable goal. Apply the mask correctly to avoid undesired results.
An optimisation goal defines the solution request type to be optimised and the goal it will attempt to achieve.
Specify the method for combining multiple goals. A weight or importance factor is assigned to the combined goal and optimised according to the combination type, for example, the average of the goals combined for the specified data.
Use optimisation with modifications made in the .pre file in EDITFEKO.
Make adjustments to the optimisation settings for a more computationally efficient solution.
