Focus Processing Options
Specify what operation should be performed on the selected goal.
The following processing steps are common to all goals.
No processing
Where the focus is non-complex, no processing steps are required. In order to consider the focus directly, the No processing option is provided.
(1) x → x
Real/Imaginary/Magnitude/Phase
Selects a specific component of a complex focus type. For an array, the complex component of each array element is taken, delivering a non-complex array.
(2) x→Re( x ) ; x→Im( x ) ; x→Phase( x ) ; x→Mag( x )
Unwrap
Unwraps a phase component. For a phase array, the whole array is considered in the unwrap process. This operator is applied directly after selecting Phase.
(3) x→unwrap( x )
Absolute value
Takes the absolute value. For an array, the absolute value of each element is taken.
(4) x → | x |
Average/Minimum/Maximum
Finds the average, minimum or maximum value of an array. This has no effect on a single value.
(5) x→ave( x ) ; x→min( x ) ; x→max( x )
Normalise
Normalises to the largest value in an array. For a single value, “1” will be returned.
(6) x →  x max( x )
Log
Takes the base-10 logarithm. For an array, the base-10 logarithm of each element of the array is taken. This operator is only available for non-complex values or arrays.
(7) x→ log 10 ( x )
Offset
Adds a specified non-complex value. For an array, the value is added to each element of the array. This operator is only available for non-complex values or arrays.
(8) x→x+n
Scale
Multiplies by a specified scale factor. For an array, each element of the array is multiplied by the scaling factor.
(9) x→nx
Exponent
Applies an exponent. For an array of values, the exponent of each value in the array is taken.
(10) x →  x n
Undefined
When a processing step is modified and the step becomes invalid, the processing step reverts to an Undefined state. Delete or redefine all Undefined steps before applying the changes to the goal.
