Feko is a comprehensive electromagnetic solver with multiple solution methods that is used for electromagnetic field analyses
involving 3D objects of arbitrary shapes.
EDITFEKO is used to construct advanced models (both the geometry and solution requirements) using a high-level scripting language
which includes loops and conditional statements.
Feko offers state-of-the-art optimisation engines based on generic algorithm (GA) and other methods, which can be used
to automatically optimise the design and determine the optimum solution.
This application macro transfers settings and application macros between different versions of Feko. This may be useful if you have customised one installation of Feko and want to use the same settings in a concurrent installation.
The application macro allows you to create an array of elements. Specify the number of elements and offset between the elements, or import
the coordinates from file to create an irregular-spaced array. For the array amplitude distribution, select
a mathematical distribution (such as cosine) or import the magnitude and phase for each element from file.
CADFEKO and POSTFEKO have a powerful, fast, lightweight scripting language integrated into the application allowing you to create
models, get hold of simulation results and model configuration information as well as manipulation of data and automate
repetitive tasks.
If you have selected Custom (import from
file) in Step 1, the file that you import must contain the magnitude, and
phase (in degrees), where the base element is the last element in
the file.
For example (if you use comma-separated
values):
1, 0
2, 20
5, 30
Figure 2
illustrates the element order when importing the magnitude and phase
from a file.
Figure 2. An example showing the element order for a 3x2 planar antenna array
where the magnitude and phase are imported from a file. The base element
is the last element specified in the file.
Under Delimiter, select the delimiter type used in the
file to be imported from the following list:
Comma
Tab
Space
Click OK to close the dialog.
The application macro creates an array
as specified.
Figure 3. An example of a custom antenna array created from a single base
element.
