The example is intended for users with no or little experience with CADFEKO. It makes use of a completed rectangular horn model to familiarise yourself with model creation in CADFEKO and viewing the simulated results in POSTFEKO.
The example is intended for users with no or little experience with CADFEKO. This example is not an example intended for simulation, but rather to familiarise yourself with model creation in
CADFEKO.
The example considers the reflection coefficient and impedance of a microstrip patch antenna on a substrate modelled
on an infinite substrate and then on a finite substrate.
Feko is a comprehensive electromagnetic solver with multiple solution methods that is used for electromagnetic field analyses
involving 3D objects of arbitrary shapes.
EDITFEKO is used to construct advanced models (both the geometry and solution requirements) using a high-level scripting language
which includes loops and conditional statements.
Feko offers state-of-the-art optimisation engines based on generic algorithm (GA) and other methods, which can be used
to automatically optimise the design and determine the optimum solution.
CADFEKO and POSTFEKO have a powerful, fast, lightweight scripting language integrated into the application allowing you to create
models, get hold of simulation results and model configuration information as well as manipulation of data and automate
repetitive tasks.
Specify the goal focus, the operations to perform on the goal, and the goal
objective.
In the model tree, on the Construction tab, select Search1 [Automatic].
On the Request tab, in the Optimisation group, click the Add goal
function icon. From the drop down list, select Far field.
The Goal focus group on the Create far
field goal dialog, contains the requested output from the Solver.
In the Focus source label field, from the drop-down list, select FarField1.
In the Focus type field, from the drop-down list select Gain.
In the Polarisation field, from the drop-down list select Total.
The Focus processing steps group on the
Create far field goal dialog specifies processing that has
to be performed prior to comparing with the objective.
In the Operation column, from the drop-down list, select Maximum.
The Goal operator group on the Create far
field goal dialog,describes how the objective and focus is
compared.
In the Operator typedrop-down list, select Maximise to
maximise the gain.
The Goal objective is the value or values with
which the focus is compared. For maximisation and minimisation the
Goal objective is disabled.
For multiple goals, the Weight will determine the
contribution of the particular goal to the global error function during
the fitness evaluation.
Click Create to create the new far field goal and
to close the dialog.
