Set Faces to Metal
Change the surface property of the patch to be metallic.
  1. Set the face of the patch to metal.
    1. In the 3D view, repeatedly left-click until the required face is highlighted in yellow.
    2. In the 3D view open the right-click context menu and select Properties.
    3. Set the Face medium to Perfect Electric Conductor.
    4. Click OK to close the dialog.
  2. Set the face of the ground plane to metal.
    1. Use the same steps as those for the patch to set the ground plane to metal.
