Configuration Tab
The Configuration tab contains the global and configuration-specific model settings and requests of the current model in tree form.
The tree contains a Definitions branch, Global branch and Configuration specific branch.
Figure 1. The Configuration tab in the model tree.
- Definitions Branch
- The Definitions branch contains by default the predefined variables, media and workplanes. When a named point or cable definition is created, it is added to the Definitions branch.
- Global Branch
- The Global branch contains the global specific model settings. From the right-click context menu define solver settings, specify the global frequency, sources, loads, networks and power.
- Configuration specific Branch
- The Configuration specific branch contains configuration specific settings. From the right-click context menu define requests per configuration, frequency per configuration, sources per configuration, loads per configuration and power per configuration.
