Run Compose in Console Mode
Opening Compose in Console mode provides a shell where Compose OML language commands can be entered at the prompt.
| For this setup | Do the following |
| Windows PC | Invoke the Compose Console via All Programs > Altair 2021.2 > Compose 2021.2 Console. |
| DOS Prompt on a PC | Run the following command: <install dir>\Compose_Console.bat or this command: <install dir>\hwx\bin\win64\ExecWinEnvComp.exe -cfg -kc -ef Comp.env -aa 0 -ex ExecMainComp.exe –toolbox -continue |
| Linux Shell | <install dir>/scripts/Compose_Console |
You can run the Console application without arguments to open it.
In Console mode, all OML Language features are exposed. However, every command related to the graphic windows (plotting, GUI, readvectorbuilder, and so on) are ignored.
