box
Turn on/off the border of a 2D plot.
box
box on
box off
- on/off
- on - turn on the 2D plot border.
Simple box example:
clf
axes
box('off')
Discover new features and enhancements.
Discover Compose, including its language support and system requirements.
The Compose tutorials and associated example model files help introduce you to the basic functionality of the software.
Learn about the features and functionality available in Compose.
Reference guides are available for functions and commands supported by OML, Tcl, and Python.
OpenMatrix is a mathematical scripting language.
The Reference Guide contains documentation for all functions supported in the OpenMatrix language.
Creates stacked areas in an axes and returns handles of the areas.
Create a new axes or set current axes by passing a handle argument.
Sets the scaling and range of x, y, and z axes (x by default). Called without arguments, axis turns autoscaling on.
Creates bars in an axis and returns handles of the bars.
Creates 3d bars on an axis and returns the handles of the bars.
Clears the current axes or axes specified by handle.
Clears the current figure or figure specified by handle.
Close the current, or a specific, or all figure window.
Gets or sets the colormap of a figure or axes.
Turns the axes colorbar on/off. Get and set the colorbar's minimum and maximum values.
Creates a 2D contoured surface in an axes.
Creates 3D contoured surface in an axes.
Creates a copy of the style properties of a plot object.
Deletes the file(s), f, or a graphic object, h.
Docks a floating figure in the main window.
Forces an update of the current axes.
Creates an elliptical shape on the figure.
Creates a surface and a set of 3D lines defined by the x, y, and z matrices.
Creates a new figure for plotting and uicontrols.
Finds all objects which have a property named propertyName and the value for such property is propertyValue.
Creates 2D filled in polygons of range x and y and color c.
Returns a handle to the current axes object.
Returns a handle to the current figure.
Returns the value of the named property p from the graphics handle, h. If property name is omitted, all properties of h will be returned.
Returns the mouse position in the figure area.
Records the mouse position(s)/keyboard input(s) in the current figure.
Properties for the graphics object in OML.
Turn on/off grid lines in a plot. Toggle the states if no argument is used.
Gets or sets user defined data in the GUI.
Creates a histogram in an axis.
Turn on/off the "hold" state of axes. When the "hold" state is on, new plotting data will be added to the axes.
Returns true if x is an axis handle; returns false if otherwise.
Returns true if x is a figure graphics handle; returns false if otherwise.
Returns true if x is a graphics handle; returns false if otherwise.
Returns true if the next plot will be added to the current one; returns false if otherwise.
Update axes' legend text, turn on/off the legend of axes. Toggle the states if no argument is used.
Add a curve in current axes or a specified axes.
Plots a given dataset in 2D axes with logarithmic scales for x and y axes.
Creates mesh in an axes and returns handles of the mesh.
Sets the style properties to a plot object.
Creates 2D or 3D patches in an axis.
Display a matrix as a heat map. The values of input matrix z are mapped to the colors of the colormap.
Plots a given dataset in 2D axes.
Creates 3D lines in an axes and returns handles of the lines.
Plots given datasets in independent y-axes and a common x-axis.
Creates a line plot in polar coordinates.
Creates a rectangular shape on a figure.
Save a figure to a specific file.
Creates dots in an axes and returns handles of the dots.
Creates 3D dots in an axes and returns handles of the dots.
Plots a given dataset in 2D axes with logarithmic scales for x axis.
Plots a given dataset in 2D axes with logarithmic scales for y axis.
Sets property values for graphics handles.
Creates a stem plot in an axis and returns the stem handles.
Creates a 3D stem plot in an axis and returns the stem handle.
Sets up a plot grid with rows by cols subwindows and sets the current axes for plotting to the location given by index.
Creates surfaces in an axes and returns handles of the surfaces.
Creates a textbox at coordinate x,y with text 't'.
Sets the title of the plot.
Creates a button group in a figure to group radio buttons.
Creates a context menu which is displayed with a right-mouse click for a figure, uitab, or select uicontrol objects.
Creates a menu item in a context menu which is displayed with a right-mouse click for a figure, uitab, or select uicontrol objects.
Creates interactive graphical control objects in a figure. Use the 'style' property of uicontrol to create different types of control objects.
Creates a menu bar for a figure.
Creates a menu item, in a menu bar, for a figure.
Creates a frame for interactive graphical control objects in a figure.
Resumes execution of code, stopping uiwait on the given handle, handle, or stopping all uiwait commands in the current session.
Creates a tab in a tabbed frame for interactive graphical control objects in a figure.
Creates a tabbed frame for interactive graphical control objects in a figure.
Creates a table in a figure.
Pauses the execution of code until the given handle, handle, is deleted, and the timeout, waittime, is reached.
Undocks a figure, making it float over the main window.
Sets the viewpoint for the current axes.
Creates a waitbar in the current session.
Pauses the GUI until a mouse button/key is pressed in the current window.
Creates waterfall meshes in an axes and returns handles of the meshes.
Annotates the x-axis.
Set and query range of x axis.
Add one or more vertical lines in the current axes or a specified axes.
Annotates the y-axis.
Set and query range of y axis.
Add one or more horizontal lines in the current axes or a specified axes.
Annotates the z-axis.
Set and query range of z axis.
box
box on
box off
Simple box example:
clf
axes
box('off')
(c) Altair Engineering, Inc. All rights reserved.
