Run Compose in GUI (Interactive and Graphic) Mode
GUI mode provides access to all editorial, execution, and management features of the Integrated Development Environment (IDE).
GUI mode can be started from the Start menu, or from a DOS prompt on a PC.
Complete the step depending on your situation.
For this setup Do the following
Windows PC for Compose From the Start menu, click All Programs > Altair 2021.2 > Compose 2021.2
DOS Prompt
Run the command <install directory>/Compose.bat
This command supports the following optional arguments:
Compose.bat -f <file> will execute <file>.
Supported extensions are .oml, .py, .tcl, and .r or .R).
Linux Shell Run the command <install dir>/scripts/Compose
