WinProp is a complete suite of tools in the domain of wireless propagation and radio network planning. With applications
ranging from satellite to terrestrial, from rural via urban to indoor radio links, WinProp’s innovative wave propagation models combine accuracy with short computation time.
View the typical workflows when working with propagation simulations in specific scenarios, how to add a network planning
to a propagation simulation, include a receiver pattern, set up a time-variant scenario, include multiple-input multiple-output
(MIMO) at both the base station and the mobile station, connectivity analysis of sensor networks and optimization.
Use AMan to generate, edit and analyze a single antenna. Superimpose multiple antennas radiating similar signals to determine
the actual antenna pattern while taking into consideration the local environment.
Predict path loss between transmitter and receiver with ProMan. Perform network planning including the wireless standards (the air interfaces) and including multiple transmitters/receivers
(multiple base stations).
The ProMan (Propagation) software package is designed to predict path loss accurately between transmitter and receiver. The ProMan (network) software offers network planning modules.
The WinProp command line interface (WinPropCLI) executable enables you to run WinProp projects in batch mode without launching the graphical user interface (GUI). It is available on both Microsoft Windows and Linux. Internally, the WinPropCLI executable calls the WinProp API. The WinPropCLI can be used within queuing systems such as Altair PBS, Torque, LSF, GridEngine and more.
WinProp features a component database with manufacturer information. Components such as combiners, splitters, amplifiers can
be added for modeling of the propagation environment.
WinProp includes empirical and semi-empirical models (calibration with measurements possible), rigorous 3D ray-tracing models
as well as the unique dominant path model (DPM).
In WinProp various air interfaces and applications are pre-defined: broadcasting, cellular, wireless access, WiFi, sensor networks,
ICNIRP and EM compliance.
Time variance influences the wave propagation significantly.
Because of time variance effects, WinProp offers a module to
consider time-variant effects in the wave propagation computation. The time-variant vector
databases are based on indoor vector databases, but extend these files with time-variant
properties. Each ordinary indoor database can be transformed into a time-variant database.
In addition to indoor databases time-variant databases offer the following features:
Motion can be assigned to all objects
Translation and rotation are possible
Figure 1. Animation of a time-variant vector database.
Generation
Time-variant vector databases can be generated with the WallMan component.
