WinProp API Examples
A number of small examples is available that illustrates how to use the WinProp API.
Note: The examples are located at %FEKO_HOME%\api\winprop\source\1.
Each WinProp API example consists of the following files:
  • CMakeLists.txt
    The CMakeLists.txt file is used to set up a Microsoft Visual Studio solution with all dependencies (linked libraries).
  • .h
    The .h is the header file. It is a text file that contains the class and function definitions.
  • .cpp
    The .cpp file contains the source code. It is a text file that contains the implementation of the class and function definitions.
1 where %FEKO_HOME% refers to the location of the Altair Feko installation, for example C:\Program Files\Altair\2021.1\feko.
