Defining the Prediction Requests
Specify the predictions to be computed.
  1. Under Computed Prediction Results, select the Field strength check box.
  2. Under Computed Prediction Results, select the Path Loss check box.
  3. Under Computed Prediction Results, select the LOS1 Analysis check box.
Note: Keep the dialog open to define additional project parameters.
1 Line-of-sight (LOS) condition: Direct line of sight between transmitted and receiver.
