Specifying the Output Folder for the Prediction Results
Specify the folder for the prediction results to be computed using the COST 231 - extended Walfisch-Ikegami model.
Launch the Edit Project Parameters dialog using one of the
following workflow:
- On the Project menu, click
Edit Project Parameters.
- On the Project toolbar, click the
Edit Project Parameters icon.
- Press F3 to use the keyboard shortcut.
- Click the Propagation tab.
Specify the output folder for the results to be computed using the dominant path model.
- Under Output Directory / Basic Filename for Propagation Results, in the Directory field, change Prop03_DPM to Results\Prop03_COST231.
