Drawing Buildings
Trace building outlines on the imported aerial photograph to draw buildings.
Trace the building in the X/Y window using one of the following
workflows:
- On the Objects menu, click Enter Basic Objects > Enter Polygonal Object.
- On the Objects toolbar, click the Add Polygonal Objects icon.
- Press F7 to use the keyboard shortcut.
- Click twice to specify the start point of the building.
Trace the building by clicking on the corners of the building.
Tip: Press Esc to exit the creation of the current polygon.
- Right-click at the start point to close the polygon.
Repeat Step 2 to
Step 4 and trace
multiple buildings.
Exit the draw mode using one of the following workflows:
- On the Objects menu, click Select Objects > Select Single Object (Mouse).
- On the Objects toolbar, click the Select Object icon.
- Press F10 to use the keyboard shortcut.
Select the building by clicking on the outline of the building.
A selected object is indicated in red.
Right-click on the selected building and from the right-click context menu, click Properties.
The Object Properties dialog is displayed.
Under Corners, select a corner and click
Edit to modify the height of the buildings.
Note: You can modify the height of any corner to change the height of the building.
- Click OK to close the Enter Coordinates dialog.
Save the outdoor database.
- On the File menu, click Save Database As.
Enter Office_Park_partial.odb as the file name for
the outdoor database and click Save.
Note: The .odb file extension stands for outdoor database binary.
