While it takes longer to load Render in Darkroom, you have the added benefits of
being able to render in queue, directly manage the stored renderings, and directly perform
post-processing.
First,
you need to do the following:
- Open or create a model with materials applied.
- Define the rendering settings.
Do one of the following:
To |
Do this |
Render the current view |
On the Rendering tab, click
Render in Darkroom icon.
![](../../../images/figures/studio/icon_render_darkroom.png)
Render selected objects |
- Select the objects you'd like to render.
- Press I to isolate the
selected objects. Isolating an object zooms in and
temporarily hides all other objects.
- On the Rendering tab, click
Render in Darkroom
icon.
- Press I again to un-isolate
the selected objects.
The Render in Darkroom window is displayed:
![](../../../images/figures/studio/render_darkroom.png)
- To the bottom left of the current rendering, the status is displayed,
including information about the rendering engine, number of samples,
remaining time, and elapsed time.
- At the bottom right of the window, the current rendering is listed in
the queue.
- Optional:
To add a job to the rendering queue, repeat the previous step.
To manage the rendering queue, you can do the following:
Table 2. Render in Darkroom Options
To |
Do this |
Note |
Start rendering |
Click Start.
![](../../../images/figures/studio/icon_rendering_play.png)
If the model you want to render is at the top of the
queue, you can click the file name to start
rendering. |
Pause rendering |
Click Pause rendering.
![](../../../images/figures/studio/icon_rendering_pause.png)
Stop rendering |
Click Stop .
![](../../../images/figures/studio/icon_rendering_stop.png)
You will be prompted to save the rendered image. |
Change the order of the queue |
Click Move Up or Move
Down. |
If a rendering is in progress, it cannot be
moved. |
Delete a rendering from the queue |
Click the file name, and then click Delete
Selected.
![](../../../images/figures/studio/icon_rendering_delete.png)
deleted. |
Once a rendering is complete, the image is stored
automatically in the Image Browser.
You can manage the stored renderings and perform
post-processing.
