Altair® Monarch®
Summary Definition Window
Use this window to create a new summary definition or to edit an existing summary definition.
To access this window, select Definition from the Summary Design ribbon.
Options
Field
Name
Enter a name for this Summary. This name will identify the Summary and will display on the list of Summaries on the Summaries Menu.
Apply Filter
Select a filter to apply to the table before Monarch Classic builds the Summary. This way you can create a summary using only a subset of data in the table.
Default style:
Displays the color style of the summary.
You can edit the color style via the Color Properties dialog by clicking the adjacent Edit button:
Note: The default style is applied to all of the summary’s cells. If you specify a title row style or total line style – or if you specify font and background colors for key, item or measure fields – these settings will override the default style ones.
Title row style:
Displays the color style of the summary’s title row.
Total Line options
Insert total line
Select to insert a total line at the bottom of the summary. The total line displays totals for all measures in the summary.
Label
Enter the name you want to apply to the summary’s total line.
Style
Displays the color style of the summary’s total label.
Insert n blank line(s) before total line
Use to specify the desired number of blank lines you want to insert before the total line.
Apply label style to measure columns
Click to make all measures columns have the same style as the Total Label.
Comment
Enter comments or notes about this summary.
