Color Properties Dialog
With this dialog you can modify the color setting for various parts of a summary. For example, you can use it to modify the text color, fill color, pattern style, and pattern color for the cells of the current summary. You can also use it to bold, italicize, or underline summary text.
options
Field |
Description |
Text |
Specifies a color for the specified summary text via the Color Selection dialog. |
B (Bold) |
Displays the specified summary text in bold font. |
I (Italics) |
Displays the specified summary text in italics. |
U (Underlined) |
Underlines the specified summary text. |
Fill |
Specifies a background color for the specified summary cells via the Color Selection dialog. |
Pattern |
Applies patterns that may be selected from a drop-down list to the specified summary cells. Colors may be selected via the Color Selection dialog by clicking on the Pattern Color Edit button . |
Pattern color |
Specifies the color you want to apply to the pattern via the Color Selection dialog. |
Preview Box |
Displays a sample of the current text, fill, and pattern colors. |
