Bridge
Use the Bridge tool to create a bridge between two or more faces of either the same PolyNURBS cage or different cages.
On the PolyNURBS ribbon, select the Bridge tool.
- Click two or more faces.
- Click the selected faces to create the bridge.
- Repeat the process to create more bridges. Right-click and mouse through the check mark to exit, or double-right-click.
