Extract a Midsurface or Face
Select a thin solid and click Extract to extract the midsurface. Use the microdialog to preview and extract a side face instead.
  1. Click on the Geometry tab.
  2. Select the Midsurface tool.
  3. Select a thin solid.
    A preview of the midsurface is shown. The thickness is automatically calculated and displayed in the microdialog, but cannot be edited.
  4. Optional: To extract a side face instead, click the icon to preview one of the side faces. Click the icon again to preview the other side face.
  5. Click the preview to confirm and extract the desired face.
    The original thin solid is deactivated.
Tip:
  • It's generally faster to extract a side rather than the midsurface, and the results will be the same.
  • To restore the original thin solid, open the Midsurface tool and select the extracted surface.
