Slice a set of solid objects with a cutting plane.
On the Geometry ribbon, select the
Slice tool.
![](../../../images/icons/inspire/icon_cut.png)
- Optional:
By default, the targets are assumed based on where you position the cutting
plane. To select your own targets, click Targets
on the guide bar, and then select one or more parts.
Click Plane on the guide bar, and then click on
the part to define the cutting plane.
As you mouse over the target, a red circular saw appears to indicate where the
cutting plane will be positioned. Hovering over an edge gives a perpendicular
cutting plane, while hovering over a face produces a planar cutting
plane.
Click Apply
on the guide bar or microdialog.
All individual solids are placed into separate parts.
Tip:
- To reposition the cutting plane using the Move tool,
click
- To align the cut plane to the x-, y-, or z-axis, click
