Tutorial: Calibrator Analysis with 3D Meshed Calibrator Dies
Model a calibrator using 3D mesh.
Open the Tutorial Model
Orient the Model
- Click the Calibration ribbon.
Click the Orient icon.
On the model, click the exit surface of the profile solid.
Select Materials
Specify Process Data: Inlet
Click the Inlet icon.
Select the profile inlet surface and edit inlet properties.
Identify Calibrator Dies
This model has two calibrator dies. Select them one at a time and update the properties.
Click the Calibrator icon.
Select calibrator_die1 and edit die properties.
- Repeat for calibrator_die2.
Identify Coolant Channels
Submit the Job for Simulation
Click
on the Analysis tool in the Run group.
Specify the parameters of the analysis process. Select 3D
Mesh and Coarse mesh size.
- Click Run.
View Simulation Results
![](../../../images/figures/extrude/tut_poly_calib_3d_results.png)
