How Do I Save Solver Temporary Files to a Different File?
- The solver writes several scratch files (.scr) during simulation. Depending on the problem size, these could occupy few GB of disc space.
- Since these files are huge, the hard drive should be faster to perform I/O efficiently else simulation time will increase.
- Open .hx file.
- Write "TmpFilesDir" pset parameter. Some example shown below.
Example: For Windows
#For Windows
pset TmpFilesDir "D:/Simulation/TMP/run1"
Example: For Linux
#For Linux
pset TmpFilesDir "/scratch/TMP/run1"
Example: For folder relative to current working folder
#For folder relative to current working folder
pset TmpFilesDir "./TMP"
- Write this pset variable after environment variable at top of .hx
file.
