Cause 1: The listed joints cannot be coupled
Click Fix to automatically change the joint type
or click Review to manually change it.
Cause 2: Only one translational and one rotational degree of freedom on a
single axis is allowed
Click Review and change the listed entity so
that it has freedom on or about only one axis.
Cause 3: The listed entity does not have an implicit joint that can be
coupled
Click Review to manually change the entity's
settings in the Property Editor to make it suitable for coupling, or
delete it.
