OS-T: 1610 Thermal Fluid-Structure Interaction Analysis on a Manifold
The purpose of this tutorial is to demonstrate how to carry out a Thermal Fluid-Structure Interaction analysis on an engine exhaust manifold with conjugate heat transfer and structural deformation.
This example is an engine exhaust manifold with conjugate heat transfer and structural deformation. The structure is gray cast iron, initially at 300 K. The manifold outer surface has a convective heat transfer coefficient of h = 6 W/m2 K at 300 K. The four inlets to the manifold are held at 500 K with air as the fluid at 5 m/s. AcuSolve passes heat fluxes to OptiStruct. OptiStruct passes the temperatures to AcuSolve.
Note: This tutorial is limited to study fluid and thermal domain only.
The AcuSolve Fluid model (FSI_AS_MANIFOLD.inp) and OptiStruct Structural beam model (FSI_OS_MANIFOLD.fem) files are in the tfsi_models.zip file. Refer to Access the Model Files.
os_1610_model
os_1610_model2
Figure 1. Fluid Structural Model
Launch HyperMesh and Set the OptiStruct User Profile
  1. Launch HyperMesh.
    The User Profile dialog opens.
  2. Select OptiStruct and click OK.
    This loads the user profile. It includes the appropriate template, macro menu, and import reader, paring down the functionality of HyperMesh to what is relevant for generating models for OptiStruct.
Import the Model
  1. Click File > Import > Solver Deck.
    An Import tab is added to your tab menu.
  2. For the File type, select OptiStruct.
  3. Select the Files icon files_panel.
    A Select OptiStruct file browser opens.
  4. Select the FSI_OS_MANIFOLD.fem file you saved to your working directory. Refer to Access the Model Files.
  5. Click Open.
  6. Click Import, then click Close to close the Import tab.
    The outline of the Fatigue Analysis setup to be achieved in the following steps.
Set Up the Model
Create Contact Surface
  1. In the Model Browser, right-click and select Create > Contact Surface from the context menu.
    A default contact surface template displays in the Entity Editor.
  2. For Name, enter FSI_Interaction_Surf.
  3. Click Color and select a color from the color palette.
  4. For Card Image, select SURF.
  5. For Elements, click 0 elements > elements and pick all the internal faces.
    Tip: To pick all the elements in the internal face, use the brake angle of 30 degrees.
    os_1610_contact_surf
  6. Click add to add the faces to the contact surface.
  7. Click return to exit from this panel.
Define Fluid-Structure Interaction Parameters
  1. In the Model Browser, right-click and select Create > Load Collector.
    A default load collector template displays in the Entity Editor.
  2. For Name, enter FSI100.
  4. For Card Image, select FSI.
  5. Input the values, as shown in Figure 3.
    See NLPARM Bulk Data Entry for more information.
    Figure 3.
Define Output Control Parameters
  1. From the Analysis page, select control cards.
  2. Click GLOBAL_OUTPUT_REQUEST.
  3. For THERMAL and FLUX, set Option to Yes.
  4. Click return twice to go to the main menu.
Create Transient Heat Transfer Analysis Subcase
  1. In the Model Browser, right-click and select Create > Load Step from the context menu.
  2. For Name, enter TFSI.
  4. For Analysis type, select Heat Transfer (transient).
  5. Input/Select the Load Collector.
    os_1610_load_collector
    Figure 4.
Submit the Job
  1. From the Analysis page, click the OptiStruct panel.
    OS_1000_13_17
    Figure 5. Accessing the OptiStruct Panel
  2. Click save as.
  3. In the Save As dialog, specify location to write the OptiStruct model file and enter FSI_OS_MANIFOLD for filename.
    For OptiStruct input decks, .fem is the recommended extension.
  4. Click Save.
    The input file field displays the filename and location specified in the Save As dialog.
  5. Set the export options toggle to all.
  6. Set the run options toggle to analysis.
  7. Set the memory options toggle to memory default.
  8. Click OptiStruct to launch the OptiStruct job.
If the job is successful, new results files should be in the directory where the FSI_OS_MANIFOLD.fem was written. The FSI_OS_MANIFOLD.out file is a good place to look for error messages that could help debug the input deck if any errors are present.
Initiate a Run
  1. Launch the Compute Console (ACC) and select the FSI_OS_MANIFOLD.fem file.
  2. Click Run.
Submit the AcuSolve Job
  1. Open the AcuSolve input file (slab_dcfsi.inp) in a text editor.
  2. Change the socket_host parameter in the EXTERNAL_CODE block to your machines hostname and save the file.
    os_1600_acusolve_command
    Figure 7.
  3. Open the AcuSolve Cmd Prompt application and enter the command: acuRun-pb FSI_AS_MANIFOLD -np 8.
    Figure 8.
If the job is successful, you will see new results files in the directory where HyperMeshwas invoked. The FSI_OS_MANIFOLD.out file is where you will find error messages that will help you debug your input deck, if any errors are present.
The default files that will be written to your directory are:
cci.txt
Contains information pertaining to model progression. Logs regarding connection establishment, initial external code handshake and subsequent time step data in conjunction with exchange/stagger.
FSI_OS_MANIFOLD.html
HTML report of the analysis, giving a summary of the problem formulation and the analysis results.
FSI_OS_MANIFOLD.out
ASCII based output file of the model check run before the simulation begins and gives some basic information on the results of the run.
FSI_OS_MANIFOLD.stat
Summary of analysis process, providing CPU information for each step during the process.
FSI_OS_MANIFOLD.h3d
HyperView compressed binary results file.
View the Results
Using HyperView, plot the Displacement contour at 1.0 s.
Figure 9.
