OS-E: 0700 Subcase Specific Model Change using 3-Rings
Demonstrates subcase specific model change feature. In this model, there are 3 rings of different sizes, Component A is the smallest ring, Component B is the middle ring, and Component C is the largest ring.
Model Description
- Red
- Blue
- Yellow
In the first subcase, the interface fit between ring A and B, and removing ring C is simulated.
In the second subcase, the status from the previous subcase is carried over; in addition, the external layer elements from ring B is removed.
- FE Model
- Element Types
- CHEXA
- MAT1
- Young’s Modulus
- 30E6 MPA
- Poisson's Ratio
- 0.3
Results
Interface Fit Between | Remove | Add | |
Load Step 1 | Component A-B | Component C | |
Load Step 2 | None | One External Layer Elements from Component B | |
Load Step 3 | Component A-B-C | Component C |
Model Files
The model files used in this example include:
<install_directory>/hwsolvers/demos/optistruct/examples/3rings_modchg_lgdisp.fem
