OS-E: 0905 Spot Weld Fatigue Analysis and Size Optimization of a Frame Structure
Demonstrates Spot weld fatigue optimization using OptiStruct.
Model Description
- FE Model
- Elements Types
- CBAR
- MAT1
- Young’s Modulus
- 2.1E5 MPA
- Poisson's Ratio
- 0.3
- Density
- 7.9E-9
Results
Model Files
The model files used in this example include:
<install_directory>/hwsolvers/demos/optistruct/examples/spotweld_cbar_opt.fem
