OS-E: 4000 Rotating Bar
This is an introductory example of the optimization of a multibody dynamics system. The object of the rotating bar problem is to minimize the maximum stress of the bar.
Model Description
The structure consists of 5 bar elements. The driving motion has a velocity of sin(2t), which is applied to the left end of the structure. Sections of the bar elements are solid circles. Design variables are the radii of the sections. The mass of the structure should be less than 10kg.
DESGLB = 4
MINMAX = 14
STRESS = ALL
SUBCASE 1
MBSIM = 1
MOTION = 1
SPC = 10
DESVAR 1 RAD1 10.00 0.05 100.0
DESVAR 2 RAD2 10.00 0.05 100.0
DESVAR 3 RAD3 10.00 0.05 100.0
DESVAR 4 RAD4 10.00 0.05 100.0
DESVAR 5 RAD5 10.00 0.05 100.0
DVPREL1 10 PBARL 1 DIM1 0.0
+ 1 1.0
DVPREL1 11 PBARL 2 DIM1 0.0
+ 2 1.0
DVPREL1 12 PBARL 3 DIM1 0.0
+ 3 1.0
DVPREL1 13 PBARL 4 DIM1 0.0
+ 4 1.0
DVPREL1 14 PBARL 5 DIM1 0.0
+ 5 1.0
DRESP1 33 STRESS STRESS PBARL SNMAX 1
+ 2 3 4 5
DRESP1 100 MASS MASS
DOBJREF 14 33 1 -1.0 1.0
DCONSTR 4 100 2.5
SPC1 10 123456 1
ENDDATA
The input file is just like one for an ordinary min-max problem. The maximum normal stress of the flexible body of the subcase 1 is to be minimized by using DOBJREF and MINMAX.
Results
- Because the stress in multibody dynamics systems is a time variant quantity, the minimization of stress in multibody dynamics analysis subcases should be a min-max problem.
- The SPC1 card fixes only 6 DOF of node 1 of the flexible body in order to remove 6 rigid body motions. If you fix more than 6 DOF of the flexible body, the additional fixed DOF become constraints of the flexible body.
- Tress output request is placed above the first subcase. If you place output request inside subcase, your output request will be ignored.
Model Files
- <install_directory>/hwsolvers/demos/optistruct/examples/rotating_bar_design.fem
