OS-V: 0100 Membrane with Hot-Spot
Test No. T1 OptiStruct examines the direct stress in y direction at a point D outside the hot-spot for linear thermos elastic analysis.
Benchmark Model
Quarter model is considered and Quad4 elements with the specific mesh specifications are used for model building. The hotspot area is maintained at a temperature 100°C.
- Hot-spot Area
- Young's Modulus
- 100 x 103 MPa
- Poisson's Ratio
- 0.3
- Coefficient of Thermal Expansion
- Remaining Area
- 1 x 10-5/°C
- Young's modulus
- 100 x 103 MPa
- Poisson's ratio
- 0.3
- Coefficient of thermal expansion
- 0.0
Linear Static Analysis Results
Quadrilateral Shells | Direct Stress in y Direction at a Point D, Outside Hot-spot (MPa) | Normalized with the Target Value |
Quad4 | 47.26 | 1.057977147 |
45.51 | 1.098659635 |
Model Files
The model files used in this problem include:
<install_directory>/hwsolvers/demos/optistruct/verification/T1Quad4.fem
Reference
NAFEMS Ltd, The Standard NAFEMS BENCHMARKS TNSB Rev. 3, NAFEMS Ltd, Scottish Enterprise Technology Park, Whitworth Building, East Kilbride, Glasgow, United Kingdom, 1990.
