OS-V: 0370 Simply-Supported Thick Square Plate Harmonic Forced Vibration Response
Test 21H OptiStruct is used to investigate the Peak Displacement in z-direction and extreme fiber bending stress at undamped Natural Frequency (at the center of the plate).
Figure 1. FE Model with Boundary Conditions and Loadcases
Benchmark Model
The 2nd order and 1st order quad elements are used to model the square plate of thickness 1.0m. The z-rotation and x, y translations are fixed for all the nodes, z-translation is fixed along all four edges, x-rotation is fixed along the edge x=0 and x=10 and y-rotation is fixed along the edge y=0 and y=10. A steady-state harmonic forced vibration F=F0 sin ωt is induced in the z-direction. (F0=106 N/m2 over whole plate, ω=2πf, f=0 to 78.17 Hz). For modal analysis solution, a damping ratio of 0.02 is applied in all 16 modes and for direct solution, Rayleigh damping factor α1=5.772 and α2=6.926×10-5 are given.
The material properties are;
Material Properties
Value
Young’s Modulus
200 × 109 N/m2
Poisson’s Ratio
0.3
Density
8000 kg/m3
Frequency Response Summary
The frequency of each targeted mode is normalized with the closed form solution.
f*
Closed form solution
  Peak Displacement (mm) Peak Stress (N/mm2) Frequency (Hz)
Reference Solution 58.33 800.8 45.90
HOE:
Direct Solution 62.633 943.67 45.21
Normalized 0.931298197 0.848601736 1.01526211
Modal Solution 62.67 944.57 45.23
Normalized 0.930748364 0.847793176 1.014813177
LOE:
Direct Solution 60 774.73 45.62
Normalized 0.972166667 1.033650433 1.006137659
Modal Solution 60.05 774.54 45.59
Normalized 0.971357202 1.033903995 1.006799737
Model Files
The model files used in this problem include:
<install_directory>/hwsolvers/demos/optistruct/verification
  • /Test21HHOED.fem
  • /Test21HHOEM.fem
  • /Test21HLOED.fem
  • /Test21HLOEM.fem
Reference
NAFEMS Ltd, The Standard NAFEMS BENCHMARKS TNSB Rev. 3, NAFEMS Ltd, Scottish Enterprise Technology Park, Whitworth Building, East Kilbride, Glasgow, United Kingdom, 1990.
