OS-E: 5000 Conjugate Heat Transfer Analysis (TFSI) of Inline-4 Engine Head with OptiStruct and AcuSolve
The Conjugate Heat Transfer Analysis of a cylinder head to evaluate temperatures in the engine block by taking into account the coupling effect with the fluid domain.
Model Description
- FE Model
- Element Types
- CHEXA
- MAT1
- Young’s Modulus
- 21500 MPA
- Poisson Ratio
- 0.3
Results
Model Files
The model files used in this example include:
<install_directory>/hwsolvers/demos/optistruct/examples/TFSI_PWT.zip
