Multiaxial Fatigue Analysis
Multiaxial Fatigue Analysis, using S-N (stress-life), E-N (strain-life), and Dang Van Criterion (Factor of Safety) approaches for predicting the life (number of loading cycles) of a structure under cyclical loading may be performed by using OptiStruct.
In Uniaxial Fatigue Analysis, OptiStruct converts the stress tensor to a scalar value using user-defined combined stress method (von Mises, Maximum Principal Stress, and so on). In Multiaxial Fatigue Analysis, OptiStruct uses the stress tensor directly to calculate damage. Multiaxial Fatigue Analysis theories discussed in the following sections are based on the assumption that stress is in the plane-stress state. In other words, only free surfaces of structures are of interest in Multiaxial Fatigue Analysis in OptiStruct. For solid elements, a shell skin is automatically generated by OptiStruct, shell elements are used as-is. Multiaxial Fatigue Analysis features are activated by setting MAXLFAT=YES on the FATPARM Bulk Data Entry.
The stress-life method works well in predicting fatigue life when the stress level in the structure falls mostly in the elastic range. Under such cyclical loading conditions, the structure typically can withstand a large number of loading cycles; this is known as high-cycle fatigue. When the cyclical strains extend into plastic strain range, the fatigue endurance of the structure typically decreases significantly; this is characterized as low-cycle fatigue. The generally accepted transition point between high-cycle and low-cycle fatigue is around 10,000 loading cycles. For low-cycle fatigue prediction, the strain-life (E-N) method is applied, with plastic strains being considered as an important factor in the damage calculation.
Sections of a model on which Fatigue Analysis is to be performed must be identified on a FATDEF Bulk Data Entry. The appropriate FATDEF Bulk Data Entry may be referenced from a fatigue subcase definition through the FATDEF Subcase Information Entry.
The Dang Van criterion is used to predict if a component will fail in its entire load history. The conventional fatigue result that specifies the minimum fatigue cycles to failure is not applicable in such cases. It is necessary to consider if any fatigue damage will occur during the entire load history of the component. If damage does occur, the component cannot experience infinite life.
Uniaxial Load
Models with uniaxial loads consist of loading in only one direction and result in one principal stress.
Figure 1. Uniaxial Load
Proportional Biaxial Load
In models with proportional biaxial loads, principal stresses vary proportionally; however, still in one direction. Typically, in-phase loading of stress components is known as proportional biaxial load. Therefore, a fatigue subcase where a single static subcase is referenced is always a proportional biaxial load.
Figure 2. Proportional Biaxial Load
Figure 3. In-Phase Load
In models with non-proportional biaxial loads, principal stresses can vary non-proportionally, and/or with changes in direction. Typically, out-of-phase loading of stress components is known as non-proportional multiaxial load.
Non-Proportional Multiaxial Load
Figure 4. Non-Proportional Multiaxial Load
Figure 5. Out-of-Phase Load
In Multiaxial Fatigue Analysis, proportional biaxial loads and non-proportional multiaxial loads are considered in OptiStruct.
Non-proportional Cyclic Loading and Non-Proportional Hardening
Non-proportional cyclic loads typically generate additional strain hardening, which is not observed in the proportional loading environment. The additional strain hardening is called non-proportional hardening and is caused by interaction of slip planes. As a result of the rotation of the principal axes (Figure 6), multiple sliding planes are active, and hardening can accumulate at a certain point, while the direction of the slip plane changes.
Figure 6. Interaction Between Slip Planes, Due to Non-Proportional Loading
The plasticity model used in Multiaxial Fatigue Analysis will take care of non-proportional hardening, if applied load is non-proportional.
Critical Plane Approach
Experiments show that cracks nucleate and grow on specific planes known as critical planes. The Critical Plane Approach captures the physical nature of damage in its damage assessment process. It deals with stresses and strains on the critical planes.
Depending on the material and stress states, the critical planes can be either maximum shear planes or maximum tensile stress planes. Therefore, to assess damage from multiaxial loads, two separate damage models are required. One is for crack growth due to shear, and the other is for crack growth due to tension.
Figure 7. Cracks Driven by Shear and Tensile Stress
Figure 8. Cyclic Torsion, Shear Strain, Tensile Strain, Shear and Tensile Damage
Any damage model can be used in the critical plane approach. The damage models require a search for the most damaging plane. There are two possible damaging (or failure) modes. One on planes that are perpendicular to the free surface which is tensile crack growth. The angle θ is the angle that a crack is observed on the surface relative to the σ x direction. The second failure system occurs on planes oriented 45 degrees to the surface, which is shear crack growth. Both in-plane and out-of-plane shear stresses are considered on this plane. θ can take on any value on the surface. The shear stress τ A is an in-plane shear stress and causes microcracks to grow along the surface. The maximum out-of-plane shear, τ B occurs on a plane that is oriented at 45 degrees from the free surface and causes microcracks to grow into the surface.
Figure 9. In-Plane Shear Stress and Normal Stress at 90 Degree Plane; In-Plane and Out-of-Plane Shear Stress at a 45 Degree Plane
OptiStruct searches for the most damaging plane by 10 degrees of θ . On each plane, OptiStruct assesses damage using tensile crack damage model and shear crack damage model. At the end of a search, OptiStruct reports damage at the most damaging plane which is a critical plane.
Stress-Life (S-N) Approach
The Stress-Life Approach for the Multiaxial Fatigue Analysis is similar to Uniaxial Fatigue Analysis. See the S-N Curve and Cycle Counting sections of Uniaxial Fatigue Analysis for introductory information for Stress-Life approach in Multiaxial Fatigue Analysis.
Mean Stress Correction
Depending on the material, stress state, environment, and strain amplitude, fatigue life will usually be dominated either by microcrack growth along shear planes or along tensile planes. Critical plane mean stress correction methods incorporate the dominant parameters governing either type of crack growth. Due to the different possible failure modes, shear or tensile dominant, no single mean stress correction method should be expected to correlate test data for all materials in all life regimes. There is no consensus yet as to the best method to use for multiaxial fatigue life estimates. Multiple methods are available and can be used concurrently in OptiStruct Multiaxial Fatigue Analysis. For stress-based mean stress correction method, Goodman model is used for tensile crack. Findley model is used for shear crack. You can define mean stress correction methods after the MCORRECT field on the FATPARM Bulk Data Entry. If multiple models are defined, OptiStruct selects the model which leads to maximum damage from all the available damage values.
Goodman Model
The Goodman model in Uniaxial Fatigue Analysis is used at critical plane to assess damage caused by tensile crack growth.
Findley Model
The Findley criterion is often applied for finite long-life fatigue.(1) Δ τ 2 + k σ n = τ f * ( N f ) b
Where, τ f * is computed from the torsional fatigue strength coefficient, τ f ' using:(2) τ f * = 1 + k 2 τ f '
The correction factor 1 + k 2 typically has a value of about 1.04. Note that τ f * has to be defined based on amplitude. If τ f ' is not defined by you, OptiStruct automatically calculates it using the following equation.(3) τ f ' = C f * 0.5 * S R I 1 W h e r e , C f = 2 1 + k 1 + k 2
The constant k is determined experimentally by performing fatigue tests involving two or more stress states. For ductile materials, k typically varies between 0.2 and 0.3. Its default value in OptiStruct is 0.3.
FKM
FKM mean stress correction is available for both Uniaxial and Multiaxial S-N Fatigue. For more information, see Mean Stress Correction under Uniaxial S-N Fatigue in the User Guide.
If CHK is set to YES in FATPARM for the proportional loadcase, the above equation is calculated on maximum shear stress plane. For more details, see Proportional Biaxial Load.
Figure 10. Analysis Flow for Stress-based Multiaxial Fatigue Analysis
Strain-Life (E-N) Approach
If the applied load is non-proportional multiaxial cyclic, OptiStruct runs the Jiang-Sehitoglu plasticity model to calculate the total strain and elasto-plastic stress.
The Jiang-Sehitoglu model is one of the more successful incremental multiaxial cyclic plasticity models. 1 In OptiStruct, isotropic hardening part is removed from Jiang-Sehitoglu's original model, which is best described in deviatoric stress space.(4) S i j = σ i j − α i j
Yield Function
The Mises yield function, F , is expressed as:(5) F = ( S ˜ − α ˜ ) : ( S ˜ − α ˜ ) − 2 k 2 = 0
The notation S ˜ is used for the deviatoric stress tensor, a ˜ is the backstress tensor and k is the yield stress is simple shear.
Flow Rule
The normality rule is given by:(6) d ε ˜ p = H 〈 d S ˜ : n ˜ 〉 n ˜
Where, ε ˜ p is the exterior unit normal to the yield surface at the loading point, as:(7) n ˜ = S ˜ − α ˜ ( S ˜ − α ˜ ) : ( S ˜ − α ˜ )
Hardening Rule
The total backstress α ˜ is divided into M parts.(8) α ˜ = ∑ i = 1 M α ˜ i
The evolution of the backstress (translation of the yield surface) for each of the parts is given by:(9) d α ˜ i = c i r i ( n ˜ − | α ˜ i | X i + 1 r i L ˜ ) d p
Where, d p is the equivalent plastic strain increment and c i , r i , and X i are three sets of non-negative and single valued scalar functions:(10) L i = α ˜ i | α ˜ i | ( i = 1 , 2 , 3 , ... M ) (11) | α ˜ i | = α ˜ i : α ˜ i ( i = 1 , 2 , 3 , ... M ) (12) d p = d ε p : d ε p
Material memory is contained in the a terms. The plastic modulus function, H , is derived from the consistency condition which requires that the stress state be on the yield surface when plastic deformation is occurring.(13) H = ∑ i = 1 M c i r i [ 1 − | α ˜ i | X i + 1 r i L ˜ i : n ˜ ] + 2 d k d p
There are four material parameters in this model, c , r , X , and k . All of these constants are computed from the cyclic stress strain curve of the material (Equation 23). A simple power function is fit to this curve to obtain three material properties; cyclic strength coefficient, K ' , cyclic strain hardening exponent, n ' , and elastic modulus, E .
The shear yield strength, k , is obtained by setting the plastic strain to 0.0002 (0.02%) and dividing by 3 . Both c and r are obtained by selecting a series of stress strain pairs along the material cyclic stress strain curve and describe the shape of the curve. Ratcheting rate is controlled by X which is set at a fixed value of 5. The number of components ( M ) is set to 10.
Non-proportional hardening is the term used to describe loading paths where the principal strain axes rotate during cyclic loading. The simplest example is a bar subjected to alternating cycles of tension and torsion loading. Between the tension and torsion cycles the principal axis rotates 45 degrees. Out-of-phase loading is a special case of non-proportional loading and is used to denote cyclic loading histories with sinusoidal or triangular waveforms and a phase difference between the loads. Materials show additional cyclic hardening during this type of loading that is not found in uniaxial or any proportional loading path.
The 90 degrees out-of-phase loading path has been found to produce the largest degree of non-proportional hardening. The magnitude of the additional hardening observed for this loading path as compared to that observed in uniaxial or proportional loading is highly dependent on the micro-structure and the ease with which slip systems develop in a material. A non-proportional hardening coefficient, a , can be introduced which is defined as the ratio of equivalent stress under 90 degrees out-of-phase loading/equivalent stress under proportional loading at high plastic strains in the flat portion of the stress-strain curve. This term reflects the maximum degree of additional hardening that might occur for a given material. OptiStruct measures the non-proportional hardening coefficient, a , at 0.003 strain amplitude using:(14) α = K ' 90 × 0.003 n ' 90 K ' × 0.003 n '
Where,(15) K ' 90 = K ' * c o e f k p 90 (16) n ' 90 = n ' * c o e f n p 90
You will need to input the coefkp90 and coefnp90. The default value of coefkp90 is 1.2. Default value of coefnp90 is 1.0.
The degree of non-proportionality, C , is a fourth ranked tensor which is a function of the plastic strain and the direction of the plastic strain increment.(17) d C i j k l = C c ( n i j n k l − C i j k l ) d p
The amount of non-proportional hardening is computed from Tanaka's parameter. 2(18) A = 1 − n α β C ξ σ α β C ξ σ γ η n γ η C i j k l C i j k l
For any proportional loading A = 0 and for 90 degrees out-of-phase loading A = 1/sqrt(2). The material constants, r i and the yield stress k are related to the non-proportional hardening parameter as:(19) d k = b ( k c − k ) d p d r i = b ( r c i − r i ) d p k c = k o ( ( N p − 1 ) A + 1 ) r c i = r o i ( ( N p − 1 ) A + 1 ) N p = 2 ( α − 1 ) + 1
The rate of hardening is controlled by the constant b . Since you are interested in the stable solution for fatigue calculations, b = 5 is selected for numerical stability. These equations are now sufficient to solve for the stresses and strains under any arbitrary loading path. The solution now proceeds by incrementally solving these equations, which can be solved in either stress, or strain control. The initial conditions are that the stress and backstress start at. All material constants start at their initial values as well and are updated after each loading increment.
Notch Correction
In uniaxial loading approximate solutions such as Neuber's rule are used to compute the stresses and strains during plastic deformation. Unfortunately, Neuber's rule cannot be directly extended to multiaxial loading because there are six unknowns and only five equations. To overcome this problem Koettgen 3 proposed a structural yield surface to obtain local elastic-plastic stresses and strains. Having defined a "yield surface," standard cyclic plasticity methods can be used to solve the unknown stresses and strains at the notch. The material memory effects are built directly into standard cyclic plasticity calculations. The method is based on the same concept at the analytical or experimental nominal stress - notch strain curves used in uniaxial fatigue analysis such as the one shown below.
Cyclically, nominal stress - notch root strain response has all the features associated with stress-strain response such as hysteresis, memory, cyclic hardening and softening. The concept of pseudo stress, σ e , or strain, ε e , is defined as theoretical elastic stress or strain computed using elastic assumptions. Neuber's rule may be written in terms of pseudo stress as:(20) σ ɛ = σ e ɛ e
These concepts can be generalized to three-dimensional stress and strain states with a structural yield surface at a notch. Having defined a structural yield surface, standard cyclic plasticity methods can be used to solve the unknown stresses and strains at the notch. For multiaxial loading, the total stress or strain is obtained by superposition of the individual load cases. A relationship between pseudo stress and notch strain is described with a power function that has the same form as a stress-strain curve.(21) ε = σ e E + ( σ e K * ) 1 n *
Where, the constants K * and n * represent the behavior of the structure rather than the material. Uniaxial Neuber's rule is employed to establish the constants E* , K * and n * .
For plane stress on the surface, σ z e , τ y z e and τ x z e are all zero and this yield function can be written as:(22) 1 2 ( σ x e − σ y e ) 2 + ( σ x e ) 2 + ( σ y e ) 2 + 6 ( τ x y e ) 2 = σ y s
This equation defines a structural yield function, F o , which has the same form as the yield functions used in the plasticity models for stress-strain calculations, that is, a Mises yield function in terms of pseudo stress.(23) F o ( σ i j e ) = σ y s
The process to calculate stress from pseudo stress is summarized as:
  1. Apply uniaxial Neuber's rule to get K * and n * (Equation 22).
  2. Run Jiang-Sehitoglu plasticity model in pseudo stress control with pseudo constants K * and n * to obtain the pseudo stress-local strain response. Now total strain is available.(24) △ ε = [ f ( K * , n * , E * ) ] △ σ e
  3. Run Jiang-Sehitoglu plasticity model in strain control with material constants K and n to obtain the local strain - local stress response. Finally, stress is also available.(25) △ σ = [ f ( K , n , E ) ] △ ε
If applied load is proportional biaxial load, you do not have to calculate incremental plastic stress and strain using Jiang-Sehitoglu plasticity model. Because direction of principal stresses do not change, you know where the maximum shear stress and the maximum tensile stress are developed and what their values are with Mohr's circle. What you need to do is convert pseudo stress range to stress range using notch correction method such as Neuber's rule or Glinka's rule. OptiStruct applies Hoffmann-Seeger method for this situation.
If only one static subcase is referenced in FATEVNT, the cyclic load is always proportional biaxial load. In this case, if CHK is set to YES in FATPARM, OptiStruct runs Hoffmann-Seeger method to calculate stress and strain from pseudo stress. If multiple static subcases are referenced in FATEVNT, currently OptiStruct runs Jiang-Sehitoglu plasticity model.
The assumptions within the Hoffmann-Seeger method are:
  • Plane stress states. Out-of-plane principal stress is zero.
  • The principal stress and strain axes are fixed in orientation.
  • The ratio of the in-plane principal stress is constant.
  • The uniaxial stress-strain curve such as Ramberg-Osgood curve can be extended for use with suitable equivalent stress and strain parameters such as the von Mises parameter
  • Hencky's flow rule is applicable.
The steps below outline how OptiStruct calculates stresses and strains based on nominal stress using Hoffmann-Seeger method.
  1. The elastic values of the signed von Mises stress and strain from nominal stress:(26) σ e q e = σ 1 e | σ 1 e | ( σ 1 e ) 2 + ( σ 2 e ) 2 − σ 1 e σ 2 e ε e q e = σ e q e E
  2. The equivalent strain and stress σ e q and ε e q is obtained by solving the following equations:(27) σ e q ε e q = σ e q e ε e q e = σ e q e E ε e q = σ e q E + ( σ e q K ' ) 1 n '
  3. Calculate plastic modulus, H .
    (28) ε p   e q = ( σ e q K ' ) 1 n '
    Plastic portion of the equivalent strain:(29) H = ( σ e q ε p  eq )
  4. The principal stresses are calculated by:(30) a = σ 2 e σ 1 e = σ 2 σ 1 σ 1 = σ e q 1 − a + a 2 σ 2 = a σ 1
  5. The principal total strains are calculated by:(31) { ε 1 ε 2 } = [ 1 E + 1 H − v E − 1 2 H − v E − 1 2 H 1 E + 1 H ] { σ 1 σ 2 } ε 3 = − ( v E + 1 2 H ) ( σ 1 + σ 2 )
The same procedure can be applied to calculate the amplitude of each quantity assuming Massing assumption is valid for equivalent stress and strain.
Where, ε a 1 ,   ε a 2 ,   ε a 3 ,   σ a 1 ,  and  σ a 2 , are obtained by:(32) a = σ a 2 e σ a 1 e = σ a 2 σ a 1 σ a 1 = σ a   e q 1 − a + a 2 σ a 2 = a σ a 1 (33) { ε a 1 ε a 2 } = [ 1 E + 1 H − v E − 1 2 H − v E − 1 2 H 1 E + 1 H ] { σ a 1 σ a 2 } ε a 3 = − ( v E + 1 2 H ) ( σ a 1 + σ a 2 )
Range of each quantity can be obtained by doubled amplitude.
Critical plane models incorporate the dominant parameters governing either type of crack growth. Due to the different possible failure modes, shear or tensile dominant, no single mean stress correction model should be expected to correlate test data for all materials in all life regimes. There is no consensus yet as to the best mean stress correction model to use for multiaxial fatigue life estimates. Multiple models are used in OptiStruct Multiaxial Fatigue Analysis. For strain-based mean stress correction, one model for tensile crack growth, Smith-Watson-Topper is used and two models for shear crack growth, Fatemi-Socie model and Brown-Miller model and the Morrow model are available. You can define damage models after the MCORRECT field on the FATPARM Bulk Data Entry. If multiple models are defined, OptiStruct selects the model which leads to maximum damage from all the available damage values.
Smith-Watson-Topper Model
This model is for tensile crack growth. In very high strength steels or 304 stainless steel under some local histories, cracks nucleate in shear, but fatigue life is controlled by crack growth on planes perpendicular to the maximum principal stress and strain. Both strain range and maximum stress determine the amount of fatigue damage.
Figure 11. SWT Damage Model
This model, commonly referred to as the SWT parameter, was originally developed and continues to be used as a correction for mean stresses in uniaxial loading situations. The SWT parameter is used in the analysis of both proportionally and non-proportionally loaded components for materials that fail primarily due to tensile cracking. The SWT parameter for multiaxial loading is based on the principal strain range, ε 1 a and maximum stress on the principal strain range plane, σ n , max .(34) ε 1 σ n , max = σ a ε a = σ a ( σ f ' E ( 2 N f ) b + ε f ' ( 2 N f ) c )
The stress term in this model makes it suitable for describing mean stresses during multiaxial loading and non-proportional hardening effects.
Fatemi-Socie Model
This model is for shear crack growth. During shear loading, the irregularly shaped crack surface results in frictional forces that will reduce crack tip stresses, thus hindering crack growth and increasing the fatigue life. Tensile stresses and strains will separate the crack surfaces and reduce frictional forces. Fractographic evidence for this behavior has been obtained. Fractographs from objects that have failed by pure torsion show extensive rubbing and are relatively featureless in contrast to tension test fractographs where individual slip bands are observed on the fracture surface.
Figure 12. Fatemi-Socie Model
To demonstrate the effect of maximum stress, tests with the six tension-torsion loading histories were conducted, that were designed to have the same maximum shear strain amplitudes. The cyclic normal strain is also constant for the six loading histories. The experiments resulted in nearly the same maximum shear strain amplitudes, equivalent stress and strain amplitudes and plastic work. The major difference between the loading histories is the normal stress across the plane of maximum shear strain.
The loading history and normal stress are shown in the figure at the top of each crack growth curve. Higher maximum stresses lead to faster growth rates and lower fatigue lives. The maximum stress has a lesser influence on the initiation of a crack, if crack initiation is defined on the order of 10 mm, which is the size of the smaller grains in this material.
These observations lead to the following model that can be interpreted as the cyclic shear strain modified by the normal stress to include the crack closure effects.(35) Δ γ 2 ( 1 + k σ n , max σ y ) = τ f ' G ( 2 N f ) b γ + γ f ' ( 2 N f ) c γ
The sensitivity of a material to normal stress is reflected in the value k / σ y . Where, σ y is stress where a significant total strain of 0.002 is used in OptiStruct. If test data from multiple stress states is not available, k = 0.3. This model not only explains the difference between tension and torsion loading, but also can be used to describe mean stress and non-proportional hardening effects. Critical plane models that include only strain terms cannot reflect the effect of mean stress or strain path dependent on hardening.
If CHK is set to YES in FATPARM for proportional loadcase, (Equation 35) is calculated on the maximum shear strain plane. For more details, see Proportional Biaxial Load. If τ f ' or γ f ' are not available, OptiStruct calculates them using the following relationship. The transition fatigue life, 2 N f , is selected because the elastic and plastic strains contribute equally to the fatigue damage. It can be obtained from the uniaxial fatigue constants.(36) 2 N f = ( E ε f ' σ f ' ) ( 1 b − c )
The Fatemi-Socie model can be employed to determine the shear strain constants.(37) Δ γ 2 ( 1 + k σ n , max σ y ) = τ f ' G ( 2 N f ) b γ + γ f ' ( 2 N f ) c γ
First, note that the exponents should be the same for shear and tension.(38) b γ = b c γ = c
Shear modulus is directly computed from the tensile modulus.(39) G = E 2 ( 1 + ν )
Yield strength can be estimated from the uniaxial cyclic stress strain curve.(40) σ y = K ' ( 0.002 ) n ' = σ f ' ε f ' b c ( 0.002 ) b c
Normal stresses and strains are computed from the transition fatigue life and uniaxial properties.(41) Δ ε p 2 = ε f ' ( 2 N t ) c Δ ε p 2 = σ f ' E ( 2 N t ) b σ n , max = Δ σ 4 = E Δ ε e 4
Substituting the appropriate the value of elastic and plastic Poisson's ratio gives:(42) Δ γ e 2 =1.3 Δ ε e 2 Δ γ p 2 =1.5 Δ ε p 2
Separating the elastic and plastic parts of the total strain results in these expressions for the shear strain life constants:(43) τ ′ f = 1.3 Δ ε e 2 ( 1 + k σ n , max σ y ) G ( 2 N t ) b γ γ ′ f = 1.5 Δ ε p 2 ( 1 + k σ n , max σ y ) 1 ( 2 N t ) c γ MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGceaqabeaacuaHep aDgaqbamaaBaaaleaacaWGMbaabeaakiabg2da9maalaaabaGaaGym aiaac6cacaaIZaGaeuiLdqKaeqyTdu2aaSbaaSqaaiaadwgaaeqaaa GcbaGaaGOmaaaadaqadaqaaiaaigdacqGHRaWkcaWGRbWaaSaaaeaa cqaHdpWCdaWgaaWcbaGaamOBaiaacYcaciGGTbGaaiyyaiaacIhaae qaaaGcbaGaeq4Wdm3aaSbaaSqaaiaadMhaaeqaaaaaaOGaayjkaiaa wMcaamaalaaabaGaam4raaqaamaabmaabaGaaGOmaiaad6eadaWgaa WcbaGaamiDaaqabaaakiaawIcacaGLPaaadaahaaWcbeqaaiaadkga daWgaaadbaGaeq4SdCgabeaaaaaaaaGcbaGafq4SdCMbauaadaWgaa WcbaGaamOzaaqabaGccqGH9aqpdaWcaaqaaiaaigdacaGGUaGaaGyn aiabfs5aejabew7aLnaaBaaaleaacaWGWbaabeaaaOqaaiaaikdaaa WaaeWaaeaacaaIXaGaey4kaSIaam4AamaalaaabaGaeq4Wdm3aaSba aSqaaiaad6gacaGGSaGaciyBaiaacggacaGG4baabeaaaOqaaiabeo 8aZnaaBaaaleaacaWG5baabeaaaaaakiaawIcacaGLPaaadaWcaaqa aiaaigdaaeaadaqadaqaaiaaikdacaWGobWaaSbaaSqaaiaadshaae qaaaGccaGLOaGaayzkaaWaaWbaaSqabeaacaWGJbWaaSbaaWqaaiab eo7aNbqabaaaaaaaaaaa@774C@
Brown-Miller Model
This model is for shear crack growth. Brown and Miller conducted combined tension and torsion tests with a constant shear strain range. The normal strain range on the plane of maximum shear strain will change with the ratio of applied tension and torsion strains. Based on the data shown below for a constant shear strain amplitude, Brown and Miller concluded that two strain parameters are needed to describe the fatigue process because the combined action of shear and normal strain reduces fatigue life.
Figure 13. Fatigue Life versus Normal Strain Amplitude
Morrow
Morrow is the first to consider the effect of mean stress through introducing the mean stress σ 0 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4Wdm3aaS baaSqaaiaaicdaaeqaaaaa@389F@ in fatigue strength coefficient by:(44) ε a e = ( σ ' f − σ 0 ) E ( 2 N f ) b MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyTdu2aa0 baaSqaaiaadggaaeaacaWGLbaaaOGaeyypa0ZaaSaaaeaadaqadaqa aiabeo8aZjaacEcadaWgaaWcbaGaamOzaaqabaGccqGHsislcqaHdp WCdaWgaaWcbaGaaGimaaqabaaakiaawIcacaGLPaaaaeaacaWGfbaa amaabmaabaGaaGOmaiaad6eadaWgaaWcbaGaamOzaaqabaaakiaawI cacaGLPaaadaahaaWcbeqaaiaadkgaaaaaaa@498A@
Thus, the entire fatigue life formula becomes:(45) ε a = ( σ ' f − σ 0 ) E ( 2 N f ) b + ε f ' ( 2 N f ) c MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyTdu2aaS baaSqaaiaadggaaeqaaOGaeyypa0ZaaSaaaeaadaqadaqaaiabeo8a ZjaacEcadaWgaaWcbaGaamOzaaqabaGccqGHsislcqaHdpWCdaWgaa WcbaGaaGimaaqabaaakiaawIcacaGLPaaaaeaacaWGfbaaamaabmaa baGaaGOmaiaad6eadaWgaaWcbaGaamOzaaqabaaakiaawIcacaGLPa aadaahaaWcbeqaaiaadkgaaaGccqGHRaWkcqaH1oqzdaqhaaWcbaGa amOzaaqaaiaacEcaaaGcdaqadaqaaiaaikdacaWGobWaaSbaaSqaai aadAgaaeqaaaGccaGLOaGaayzkaaWaaWbaaSqabeaacaWGJbaaaaaa @524D@
Morrow's equation is consistent with the observation that mean stress effects are significant at low value of plastic strain and of little effect at high plastic strain.
Influence of Normal Strain Amplitude
Analogous to the shear and normal stress proposed by Findley for high cycle fatigue, they proposed that both the cyclic shear and normal strain on the plane of maximum shear must be considered. Cyclic shear strains will help to nucleate cracks and the normal strain will assist in their growth. They proposed a simple formulation of the theory:(46) Δ γ ^ 2 = Δ γ max 2 + S Δ ε n
Where, Δ γ ^ is the equivalent shear strain range and S is a material dependent parameter that represents the influence of the normal strain on material microcrack growth and is determined by correlating axial and torsion data. Δ γ max is the maximum shear strain range and Δ ε n is the normal strain range on the plane experiencing the shear strain range Δ γ max . Considering elastic and plastic strains separately with the appropriate values of Poisson's ratio results in:(47) Δ γ max 2 + S Δ ε n = A σ f ' E ( 2 N f ) b + B ε f ' ( 2 N f ) c
Where,
A = 1.3 + 0.7 S
B = 1.5 + 0.5 S
Mean stress effects are included using Morrow's mean stress approach of subtracting the mean stress from the fatigue strength coefficient. The mean stress on the maximum shear strain amplitude plane, σ n is one half of the axial mean stress leading to:(48) Δ γ max 2 + S Δ ε n = A σ f ' − 2 σ n , m e a n E ( 2 N f ) b + B ε f ' ( 2 N f ) c
Select either the Fatemi-Socie model or the Miller-Brown model for shear crack growth mode. The SWT model is always used for tensile crack growth. Morrow method is also available.
If CHK is set to YES in the FATPARM Bulk Data Entry for proportional load cases, the above equation is calculated on the maximum shear strain plane. For more details, see Proportional Biaxial Load.
In case of proportional load, you do not have to search critical plane to find maximum damage plane, because direction of principal stress and principal strain do not change, you know the direction of plane where the maximum shear stress amplitude and the maximum normal stress amplitude. At the plane, you can easily calculate required information using Mohr's circle.
If CHK is set to YES in FATPARM for proportional load case, damage in Fatemi-Socie model is calculated on maximum shear strain plane, which is 45 degrees away from a principal stress plane.
Damage in a SWT model is calculated in the maximum principal stress plane.
Likewise, damages in Brown-Miller and Findley models are calculate on the maximum shear strain plane and maximum shear tress plane, respectively.
Figure 14. Analysis Flow for Strain-Based Multiaxial Fatigue Analysis
References
Used to predict if a component will fail in its entire load history. In certain physical systems, components may be required to last infinitely long.
For example, automobile components which undergo multiaxial cyclic loading at high rotational velocities (like propeller shafts) reach their high cycle fatigue limit within a short operating life. The conventional fatigue result that specifies the minimum fatigue cycles to failure is not applicable in such cases. It is not necessary to quantify the amount of fatigue damage, but just to consider if any fatigue damage will occur during the entire load history of the component. If damage does occur, the component cannot experience infinite life. Fatigue analysis based on the Dang Van criterion is designed for this purpose.
Fatigue crack initiation usually occurs at zones of stress concentration such as geometric discontinuities, fillets, notches and so on. This phenomenon takes place in the microscopic level and is localized to certain regions like grains which have undergone local plastic deformation in characteristic intra-crystalline bands. The Dang Van approach postulates a fatigue criterion using microscopic variables in the apparent stabilization state; this is a state of elastic shakedown if no damage occurs. The main principle of the criterion is that the usual characterization of the fatigue cycle is replaced by the local loading path and so damaging loads can be distinguished.
The general procedure of Dang Van fatigue analysis is:
  1. Evaluate the macroscopic stresses σ i j ( t ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4Wdm3aaS baaSqaaiaadMgacaWGQbaabeaakmaabmaabaGaamiDaaGaayjkaiaa wMcaaaaa@3C4E@ , for each location at a different point in time.
  2. Split the macroscopic stress σ i j ( t ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4Wdm3aaS baaSqaaiaadMgacaWGQbaabeaakmaabmaabaGaamiDaaGaayjkaiaa wMcaaaaa@3C4E@ into a hydrostatic part p ( t ) and a deviatoric part S ij ( t ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4uamaaBa aaleaacaWGPbGaamOAaaqabaGcdaqadaqaaiaadshaaiaawIcacaGL Paaaaaa@3B63@ .
  3. Calculate the stabilized microscopic residual stress d e v   p * MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamizaiaadw gacaWG2bGaaGPaVlaadchacaGGQaaaaa@3BF2@ based on the following equation:
    (49) d e v   p * = M i n ( M a x ( J 2 ( S i j ( t ) − d e v   p ) ) )
    The expression is minimized with respect to ρ and maximized with respect to t MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiDaaaa@36EF@ .
  4. Calculate the deviatoric part of microscopic stress.
    (50) s ij ( t )= S ij ( t )+dev  p *
  5. Calculate factor of safety (FOS):
    (51) F O S = M i n ( b τ ( t ) + a p ( t ) ) (52) τ ( t ) = 0.5 T r e s c a ( s i j ( t ) )
    Where, b MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOyaaaa@36DD@ and a MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOyaaaa@36DD@ are material constants.
    If FOS is less than 1, the component cannot experience infinite life.
OptiStruct Factor of Safety Setup
  1. The torsion fatigue limit and hydrostatic stress sensitivity values required for an FOS analysis can be set in the optional FOS continuation line on the MATFAT Bulk Data Entry.
  2. The Dang Van criterion type can be selected on the FATPARM Bulk Data Entry.
  3. Factor of Safety output can be requested using the FOS I/O Options Entry.
1 Jiang and Sehitoglu "Modeling of Cyclic Ratcheting Plasticity, Part I: Development of Constitutive Equations," Journal of Applied Mechanics, Vol. 63, 1996, 720-725
2 Tanaka, E., "A Non-proportionality Parameter and a Cyclic Viscoplastic Constitutive Model Taking into Account Amplitude Dependencies and Memory Effects of Isotropic Hardening," European Journal of Mechanics, A/Solids, Vol. 13, 1994, 155-173)
3 Koettgen V.B., Barkey M.E., and Socie, D.F. "Pseudo Stress and Pseudo Strain Based Approaches to Multiaxial Notch Analysis" Fatigue and Fracture of Engineering Materials and Structures, Vol. 18, No. 9, 1995, 981-1006)
