Solution Sequences
OptiStruct can be use different solution sequences for aircraft analysis.
Some of the OptiStruct solution sequences that can be used are:
STATICS
Linear Static or Nonlinear Static Gap Analysis
MODES
Normal Modes Analysis
BUCK
Linear Buckling Analysis
DFREQ
Direct Frequency Response Analysis
LGDISP
Large Displacement Nonlinear Static Analysis (available as PARM card entry)
HEAT
Linear Steady-state or Transient Heat Transfer Analysis
FATIGUE
Fatigue Analysis
Static Analysis
OptiStruct can be used to solve time-independent static analysis. Figure 1 shows a fuselage section with SPC boundary conditions on the bulkhead and a uniform pressure applied to the skin.
Figure 1. Stress and Displacement Contours for Static Analysis of a Fuselage Section
For further information, refer to Linear Static Analysis.
An analysis is termed nonlinear when the relationship between the Force and Displacement is nonlinear. Most of the structural components in an aircraft structure are subjected to large deformations, which are best analyzed through nonlinear analysis. The main reasons for nonlinearity are:
  • Material nonlinearities
  • Geometric nonlinearities
  • Presence of nonlinear forces
  • Contact nonlinearities
Inertial Relief Analysis
Inertia relief analysis is mostly performed on unsupported structures to determine the impact loads of structures or to calculate the distribution of forces. OptiStruct has two options for Inertia relief analysis.
  • PARAM, INREL, -1 is used when certain boundary conditions are specified.
  • PARAM, INREL, -2 is used when no boundary conditions are specified.
Figure 2. Displacement and Stress Contours for Inertia Relief Analysis
Figure 2 shows the results from an Inertia Relief Analysis performed on a fuselage model.
Mode shapes provide the frequencies at which the structure will absorb all the supplied energy when no load is acting on it. To analyze the displacement of a structure at these frequencies, you can use Frequency Response Analysis. Normal Modes Analysis of aircraft structures will help in determining:
  • Under constrained and loose components
  • The rotating speed which matches the natural frequencies in case of the analysis of a blade or a rotor
  • The areas to be constrained or loaded.
Figure 3. Normal Modes Analysis of a Fuselage and Drone
Figure 3 shows the results from the Normal Modes Analysis for a fuselage and a drone. Both models have free-free boundary conditions.
Each frequency is solved independently and can also solve a several frequencies at a time. This can be further used to determine the displacement versus frequency plots. This helps to study the displacements of the structure when subjected to its natural frequency calculated using Modal Analysis. The frequencies can be specified using the FREQi card.
Figure 4. Frequency Response Analysis of a Fuselage Section
Model File
<install_directory>/hwsolvers/demos/optistruct/examples/Fixedwing_modal.fem
