ACDISP
I/O Options and Subcase Information Entry Used in the I/O Options section or in Acoustic Complex Eigenvalue Analysis Subcases to request displacement for acoustic grids. This output request is only supported for acoustic interface grids.
ACDISP (format) = option
Argument Options Description
format <H3D, COUPLED, blank>
Default = blank
H3D
Results are output in Hyper3D format (.h3d file).
COUPLED
Results are only output for structural displacements at wetted surface.
blank
Results are output in all active formats for which the result is available.
option <YES, ALL, NO, NONE, SID>
Default = ALL
YES, ALL, blank
Displacement is output for all acoustic interface grids.
NO, NONE
Displacement is not output for any acoustic interface grids.
SID
If a set ID is given, displacement is output only for acoustic interface grids listed in that set.
  1. When ACDISP command is not present, acoustic interface grid displacement is not output for acoustic complex eigenvalue subcases.
  2. Multiple instances of this card are allowed; if instances are conflicting, the last instance dominates.
  3. When ACDISP is present in an acoustic fluid-structure model, the following results are output.
    • Displacement of fluid acoustic interface grids
    • Displacement of structural acoustic interface grids
    • Fluid Pressure results are also output
