Response Variables
Model behavior is captured in terms of Response Variables.
These are the functions ψ ( ... ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbdfgBPj MCPbqefqvATv2CG4uz3bIuV1wyUbqeduuDJXwAKbYu51MyVXgaruWq VvNCPvMCG4uz3bqeeuuDJXwAKbsr4rNCHbGeaGqiVu0Je9sqqrpepC 0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yq aqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaGaaiGadmWaamaaci GaaqqaceqbcaGcbaGaeqiYdKNaaiikaiaac6cacaGGUaGaaiOlaiaa cMcaaaa@423B@ , in the equations in the Optimization Problem Formulation section. The optimizer in MotionSolve works with Response Variables. Response Variables are used to define the cost and constraint functions for the optimization problem. The MotionSolve optimization toolkit provides a library of responses that you can use to define cost and constraint functions. You can, if you wish, create your own response variables and use it.
The following responses are available in MotionSolve:
